I would like to get the part number for Pcb mountable High Voltage Transformer with the following specifications
HV flyback transformer
- PCB‑mountable
- 30–60 W
- 5–15 kV output
Thank you for your inquiry and welcome to the community.
I’m not seeing that we have a transformer that meets your requirements.
Hi orders.space,
I believe such transformers are typically custom-designed for the specific application because any standard parts would likely not be optimized for any particular design.
You might try contacting a company such as Würth Elektronik, who makes a lot of custom-designed transformers.
