HM01B0-MNA-00FT870 — RGB Bayer or monochrome?
I am considering purchasing DigiKey part number 3367-HM01B0-MNA-00FT870-ND, manufacturer part number HM01B0-MNA-00FT870.
The datasheet lists the color filter array as “Bayer, Monochrome”, but it does not clearly state which version corresponds to this exact manufacturer part number.
Could you please confirm whether HM01B0-MNA-00FT870 is:
  • the RGB Bayer color version, or
  • the monochrome version?
If this exact part number can be supplied in both variants, could you please provide the complete ordering code that uniquely identifies the RGB Bayer version?
I need confirmation for the actual part stocked by DigiKey, not only for the HM01B0 product family in general.
Thank you.
Greetings,
P.7 of the linked datasheet suggests that the reference to monochrome is likely in relation to a binned readout mode, rather than physical sensor implementation:
