Hole Diameter Tolerances and Positional Tolerance of the12-140 thru holes
------Question for 12-140 Please Put your question below------
Hi,
What are the thru hole diameter tolerances and positional tolerances of the thru holes?
I found in the drawing the nominal diameter is .174”.
Trying to determine positional tolerance I need for the holes with inserts in the terminal block will mount to.
Thank you
I can’t find mention of dimensional tolerances in any of the publicly available drawings for Cinch’s barrier blocks.
Since they’re injection molds based on CAD models the dimensions are likely not going to be far off the drawing.
