------Question for EVAL-ADXL356CZ Please Put your question below------
Hi, I have recently ordered the above part and am in process of designing an attachment plate for it. As such I will need to know the hole placement and chip dimensions. Is there a dimensioned model of this part available?
Thank you!
Greetings @jecunningham
Breakout Board documentation can be found here:
Evaluating the ADXL354 / ADXL355 / ADXL356 / ADXL357 [Analog Devices Wiki]
With Gerber files for the ADXL355/ADXL354.
I took a look at the files, and there does not appear to be anything which gives the dimensioning of the spacing of the screw attachment holes/placement on the breakout board, which is what I’m searching for. Are there other documents available which include this?
Thanks,
Joseph
They provide the Gerbers for the ADXL354/ADXL355 which looks like follows the same board size dimensions.
Using a free Gerber file viewer here is what I found: Approx 14.80mm square pattern:
Thank you, that’s what I needed! I’ve never used Gerber files before, so I probably just missed what I needed there. Looks like the hole spacing is 10 mm, so I can forward that on to my designer.
Thanks again!
Joseph
The hole spacing is approx 14.8mm.
