How can I order this potentiometer P11S2V0FGSY00D0283 in 2 or three values?
How can I order p11s potentiometers in the values of 4.7k and 22 in the same potentiometer and one of 22k, 4.7 and 4.7 in the same potentiometer?
Thank you very much for your help.
Hello edsonmanzoo, thank you for the question. It’s a little difficult to tell how that is accomplished in the datasheet. I think you have to contact Vishay with the number of modules you want and try to follow the format on page 14. Their contact info is found on the datasheet: sferpottrimmers@vishay.com
Page 9 gives information as to what values can be applied, each module would need it’s own resistance code.
You would want to build your part number here:
P11 Panel Potentiometer Part Number Generator | Vishay
and then email that part number to sferpottrimmers@vishay.com to inquire about how to get them.
I appreciate your help.
