Power sequencing is the controlled process of enabling or disabling power rails in a predefined order and with specific timing requirements. Failure to follow the recommended sequencing order can lead to degraded performance or malfunction of the load. Under extreme conditions, the load may be permanently damaged. It is also important to note that power sequencers are not the same as voltage supervisors though. For more details, please refer to the blog What is the difference between a power sequencer and a voltage supervisor?
Figure1: Power supply sequencing waveforms (credits: Analog Devices).
As indicated by Figure 1, the power supply sequencing cycle consists of three key stages: power-up sequencing, system monitoring, and power-down sequencing.
Power-up phase.
- During the power-up sequence, each supply rail is enabled in the prescribed order and must reach its target voltage within a specified timeframe.
Monitoring phase
- During monitoring, all supplies are required to stay within their defined overvoltage and undervoltage thresholds.
Power-down phase
- During the power-down sequence, the supplies are disabled in a controlled order, which may differ from the power-up sequence, and must shut down within the configured timing limits.
Related product from Analog Devices
ADM6840 Adjustable Power Sequencer and Supervisor
Further Read
