How does the switchover circuit prevent backup batteries from powering the system normally?
The circuit comprising R1, R2, and R3, along with MOSFET M1 monitors the main input.
Figure 1. The switchover circuit.
While the main supply is active, M1 holds the lower LT4423 in shutdown, preventing the backup batteries from powering the load unnecessarily.
When the main input drops, M1 switches off, the (SHDN) ̅ pin of the lower LT4423 is pulled high, and the lower device is switched on
The upper device detects that its OUT pin is higher than its IN pin (now at 0V) and switches off, blocking any current leaking from the output to the main input.
The LT4423 provides a low forward voltage drop of approximately 15 mV and helps control which supply powers the load.
Related Topics:
What is the purpose of the backup battery system in a burglar alarm?
How does the backup battery system work when the mains power supply fails?
Applicable Part Numbers
LT4423AV#TRPBF
505-LT4423AV#TRPBFCT
505-LT4423AV#TRPBFTR-ND
505-LT4423AV#TRPBFCT-ND
505-LT4423AV#TRPBFDKR-ND
