Question: Can you measure the average and RMS values directly in the waveform viewer without adding a .MEAS directive?
Answer: Yes. LTspice provides a quick measurement feature in its waveform viewer. Follow these steps:
- Run a transient simulation, then click the output node
outin the schematic to display theV(out)trace. - If necessary, zoom the time axis to the interval you want to measure.
- Hold down Ctrl and click the trace label
V(out)at the top of the waveform viewer to open the measurement popup.
Figure 1 : The Ctrl+Click measurement popup shows an Average of 3 V and an RMS value of approximately 4.1231 V over the 0–5 ms interval. (Image source: ADI.)
Note: The measurements apply to the selected time interval. Measuring only part of a sine-wave cycle may produce values that differ from the complete-cycle theoretical results.
Related Articles :
- LTspice Waveform Measurements: Average and RMS Values
- What Is the Difference Between Average and RMS in LTspice? Why Are the Results 3 V and 4.123 V?
- How to Check Average and RMS in LTspice with Ctrl+Click?
- How to Use .MEAS to Calculate Average Voltage, RMS Voltage, Current, and Power in LTspice?
- How to Use .STEP and .MEAS to Compare RMS Values at Different DC Offsets in LTspice?
Related ADI References:
- ADI, LTspice: Measuring the Average and RMS Values of a Trace
- LTspice Official Website and Download
- ADI: LTspice: Computing the Average or RMS Value of a Trace
