How to connect the I2C interface module to the NEVO+ Power Supply Series
The NEVO series power supplies offer a modular, user configurable solution. With a variety of rated output modules, adjustable voltage, and the ability to connect in series and parallel, providing unrivalled performance and flexibility.
To increase this flexibility even further, the I2C Interface allows NEVO outputs to be digitally controlled via low cost microcontrollers or computers.
To use the I2C interface, simply connect the I2C cable plug to the J5 socket of the NEVO output module. Then connect the I2C interface to your Microcontroller via the socket at the bottom of the device.
The I2C interface will convert the digital commands into accurate analog control signals for the NEVO output module to provide full voltage and current control of the output.
For details such as memory addresses, voltage and current control equations and more, please consult the datasheet for the I2C Interface
View the NEVO+ Series - I2C interface connection demonstration video
Nevo Series Currently Carried by DigiKey
