In installation of a deb package file, for some packages, it waits for
Processing triggers for man-db
for very long time. Is there a way/option not to install man-db ? Such as :
sudo dpkg -i ./libncurses6_6.1+20181013-2+deb10u2_armhf.deb
Or is it possible in some where with a flag to disable man-db installation all-together, because no one uses on-machine manual anymore.
Hi Robert,
I had executed the command:
sudo apt remove man-db --purge
then installed some packages (but the psmisc installation triggered building manual again):
It seems the man-db trigger is embedded in the deb package. Hope there is a way to disable or exclude it. If not, it is not biggie.
