How to order alternative version of Vishay NTC not listed
Hello. The Vishay NTCASCWE3472J, your # BC2391-ND is according to their datasheet available with “insulated leads upon request”. How can I order this ?
Greetings,
Since the published documentation does not appear to provide a part number/ordering code for the specific item requested, you would need to first contact the manufacturer to obtain one.
You could then forward this information from the manufacturer to the sales group and request a non-catalog quote, with the understanding that there will be a significant minimum order quantity and lead time, and and that any purchase transaction will be on non-cancellable, non-returnable terms.
Unless the quantities in question are substantial, adding a few pieces of heat shrink tubing is likely to be a path of lesser resistance.
