How to trim the output voltage on CPP4B36T
------Question for CPP4B36 Please Put your question below------
I can’t find a data sheet for CPP4B36TM that shows how to trim the output voltage. Is there a trim potentiometer, or a resistor to connect to the trim pin?
Hello and welcome to our community.
I will ask the manufacture for more information and get back to you.
Thank you for your patience.
Here is your case number, tech reference number T4905517
CPT4B36 Datasheet R_1.1.pdf (588.6 KB)
Attached is the datasheet with the trimming instructions.
Thank you Nathan!
