Question: If you want to record several measurements automatically, do you have to click each waveform trace manually?
Answer: No. You can use .MEAS directives to write measurement results to the SPICE Output Log when a transient simulation finishes. For the example with a 50 Ω load, use these five measurements:
.meas TRAN Vavg AVG V(out)
.meas TRAN Vrms RMS V(out)
.meas TRAN Iavg AVG I(Rload)
.meas TRAN Irms RMS I(Rload)
.meas TRAN Pavg AVG V(out)*I(Rload)
Figure 1 : Example circuit. The V(out) and I(Rload) traces are used to measure output voltage, load current, and power. (Image source: ADI.)
For the 0–5 ms measurement interval, the SPICE Output Log reports approximately:
| Measurement | Result |
| Average output voltage, Vavg | 3 V |
| RMS output voltage | 4.1231 V |
| Average load current, Iavg | 0.0600 A |
| RMS load current | 0.082462 A |
| Average load power, Pavg | 0.3400 W |
After the simulation, select View → SPICE Output Log or press Ctrl+L to view the results.
Related Articles :
- LTspice Waveform Measurements: Average and RMS Values
- What Is the Difference Between Average and RMS in LTspice? Why Are the Results 3 V and 4.123 V?
- How to Check Average and RMS in LTspice with Ctrl+Click?
- How to Use .MEAS to Calculate Average Voltage, RMS Voltage, Current, and Power in LTspice?
- How to Use .STEP and .MEAS to Compare RMS Values at Different DC Offsets in LTspice?
Related ADI References:
- ADI, LTspice: Measuring the Average and RMS Values of a Trace
- LTspice Official Website and Download
- ADI: LTspice: Computing the Average or RMS Value of a Trace
