HS2P6F26
------Question for HS2P6F26 Please Put your question below------
I need HS2P6F26. You show HS2P6F26-BPE. If I purchased HS2P6F26-BPE could I remove that suffix (is it a nut and contacts) or is it structurally a different connector?
Hello, welcome to the TechForum!
It looks like the datasheet says that the BPE on the part number calls out a rear panel mount, epoxy sealed PC terminal version of this connector. If these differences will still work for you then I believe this could be a possible cross for your part.
