------Question for HD3-4702-9Z Please Put your question below------
Looking for HS3-4702-9 (Bit Rate Generator IC 1MHz 1 16-DIP) do you have any equivalent IC’s?
closest equivalent part in different package is:
HD4-4702-9
as IC BIT RATE GEN in 18CLCC from Harris Corporation
Hello charlesb,
I did find a closer match, but the Marketplace vendor requires an 8 piece minimum order.
Part number is 2156-5962-9051801MEA-ND, which is the 16 pin DIP IC.
This can handle a higher temperature range, and seems to be a close match. Please check the datasheet to verify compatibility to your application.
If this would work for you, and you are only needing one, you can take the manufacturer’s part number 5962-9051801MEA, and search it on Google, to see if anyone sells them individually.
