I need the external drawing of the following product
------Question for 2146541633 Please Put your question below------
I am contacting you using Google Translate.
I need the external drawing of the following product.
Product Name: 2146541633
DigiKey Product Number: 900-2146541633-ND
2146541633 Molex | 센서, 트랜스듀서 | DigiKey
Please check.
— 원문 —
구글 번역기를 사용하여 문의 드립니다.
아래 제품의 외형 도면이 필요합니다.
품명 : 2146541633
DigiKey 제품 번호 : 900-2146541633-ND
확인 부탁드립니다.
Welcome to the DigiKey TechForum. Here is the drawing for DigiKey part 900-2146541633-ND
이런 도면은 없나요?
The manufacturer does not appear to have provided a drawing with additional dimensions, though if one assumes that the drawing provided is to scale regarding the ring connector, the outer diameter would appear to be approximately 5.8mm and overall length 10mm.
