------Question for N206-BC01-IND Please Put your question below------
To make your own cable that can mate to that Jack the N206-WK01-IND was found.
N206-WK01-IND Eaton Tripp Lite | Cables, Wires - Management | DigiKey
You would put the un-connectored cable through the back of this first then install the connector.
This would then be able to clamp down on to the cable with the gland in the back for the IP rating.
Otherwise you can use the pre-made cables the manufacturer has available.
Modular/Ethernet Cables (RJ45, RJ11) | Electronic Components Distributor DigiKey
Thank you very much
