I need to find a comparable alternative for this part that has a short lead time
------Question for ACD-07AFMM-SL7A03 Please Put your question below------
Part # ACD-07AFMM-SL7A03. Do you have a comparable alternative to this part with a short lead time preferably 1 week
Hi ordering,
Welcome to the TechForum.
The ACD-07AFMM-SL7A03 is a non-stocking cable assembly for us so one would need to order the minimum order quantity of 10 pcs and wait the full lead time for it.
The cable assembly uses the Amphenol LTW Ceres Middle C size 7-pin threaded mate connector, which, as far as I know is not compatible with any other series of connectors.
The only other option would be to order the connectors and plain cable separately and assemble them. The connector that comes with the ACD-07AFMM-SL7A03 is molded onto the cable, but we stock a field-installable version of the same connector, listed here:
Here’s a link to some possible cables one might chose to use with the connector.
I’m sure this isn’t an ideal solution for you, but it may work in a pinch if you don’t need to make too many cable assemblies.
