I want to buy this for a company and i wanted to ask if its the same product
------Question for PSAA30R-120-R Please Put your question below------ https://www.digikey.hk/en/products/detail/phihong-usa/PSAA30R-120-R/2635780 is this the same charger ?
Hello yazanash96,
Part number 993-PSAA30R-120-R-ND has the same manufacture part number, so it would be the same charger. It will have the same input voltage, same output voltage, current and wattage.
The one thing that could be different, is the output connector on the cable.
Please verify that you need the 2.1mm X 5.5mm X 10.0mm barrel connector for your application.
Please check the datasheet to help verify compatibility.
Also, the input adapter is sold separately, so you have to determine the plug needed, and order that part number as well.
Thanks ill make sure ,what country is the origin of the charger (made in ..)
