I want to check device compatibility
I currently want to erase data from a SAS server HDD, but I’m not sure if the “SDOCK1EU3P2” erasing device can handle it.
HPE hard drive code: “HPE P/N: P13948 - 002”
Thank You
Hello Seta, welcome to the TechForum,
I am checking on this. Will let you know when I have the answer.
This adapter is SATA only, doesn’t understand SAS commands:
Look at: SATSASDUPE11 StarTech.com | Accessories | DigiKey
which supports both SAS/SATA and has an erase function..
Regards,
