IDC777 Bluetooth HFP module: can PCM/I2S input feed mSBC hands-free uplink?
------Question for IDC777-1 Please Put your question below------
Hi everyone,
I’m evaluating the IDC777 Bluetooth audio module, or a similar DigiKey-available module, for an embedded hands-free voice project.
The datasheet lists HFP/HSP, Wide Band Speech, UART control, and digital audio interfaces such as PCM/I2S/SPDIF.
My key requirement is specific:
Can externally supplied digital audio on PCM or I2S be used as the microphone source for HFP Hands-Free uplink to a phone?
I am not looking for A2DP input, analog microphone input, or a general “I2S supported” answer. I need the digital input to feed the HFP/SCO/eSCO voice uplink.
Questions:
  1. Does the standard IDC777 AudioAgent firmware support HFP Hands-Free role with mSBC/Wide Band Speech?
  2. Can external PCM or I2S input be selected as the HFP microphone/uplink source?
  3. Can it accept already-processed 16 kHz mono PCM from an external DSP and transmit it over HFP mSBC?
  4. Can far-end call audio be output over PCM/I2S, or only analog?
  5. What UART command or configuration selects the HFP microphone source and audio routing?
  6. Can onboard DSP, noise reduction, AGC, or echo processing be bypassed/minimized?
  7. Is this supported by the standard shipped firmware, or would custom firmware be required?
  8. Is there a command manual or application note that explicitly documents HFP audio routing over PCM/I2S?
Any confirmation, app notes, command references, or alternative module suggestions would be appreciated.
Thanks.
Welcome to the TechForum.
We are looking into this request and will get back most likely tomorrow.
Thank you
Ryan
