Identification of 2.0mm Pitch Locking Connector
Request: I am looking for a 6-pin, single-row, wire-to-board female housing and its matching PCB header with the following specific physical characteristics:
  • Pitch: 2.0mm (confirmed, not 2.5mm or 2.54mm).
  • Positions: 6-Pin (6P), Single Row.
  • Locking Mechanism: Features an external top-mounted friction lock/buckle (positive lock) on the plug housing.
  • Keying/Rails: It has specific internal guide rails (ribs) located in the middle, positioned between the outer side walls and the top locking latch.
  • Mating Header Style: Must mate with a 4-wall (fully boxed/shrouded) vertical or right-angle header that has a corresponding “catch” for the top buckle.
  • Visual Reference: Very similar to the HY2.0 or PHB series (often used in M5Stack or specialized Chinese electronics), but requires the specific center-rail keying.
Goal: I am looking for the manufacturer part numbers for both the female crimp housing and the vertical through-hole PCB header.
I’m not seeing anything that visually matches your example.
If you’re looking for something that generally meets your specifications possibly Part Number:
PAP-06V-S from JST
