Identify SMD circuitos de protección de mosfet doble
Hi there! can anybody identify this part?
Ii think it is a Curcuit mosfet doble, but I need de find the right reemplacement! Any idea? Thank you so much
Hi nonobudget,
Welcome to the TechForum.
I agree that it’s almost certainly a MOSFET. Can you also show a few more of the parts around it – particularly the one directly below?
This sometimes help narrow things down a bit.
Hi nonobudget,
Looks like it’s the MTE010P06H8 from CYStek. From the datasheet:
The following are a few parts with fairly similar specs to consider. None have identical specs, so the best choice may vary depending on the particulars of your application, and it’s possible that none would be suitable, also depending on the specific requirements of your application. You will need to compare the datasheet specs and decide which, if any is the best option for your application.
Here’s a link to a larger list of options if none of the above seems suitable.
Thanks so much!!! I will try this one and tell you if it works
