Identifying Display
i am trying to replace the display inside the cluster of my dad’s car.
All the information I have is about the dimensions of the display, plus a code from local company (this one is out of production), and the car which is from.
Fiat Stilo 2006 year (engine type doesn’t matter)
Dimension: 85 x 40 x 3 mm
6 pin connection
And some photos … i think that i don’t have enough knowledge about display world, but i believe that i can find it somewhere.
Thank you!
Forgot to type the code…
SEI-DISP329V1
Hi Strazzy,
Displays like that for automotive applications are almost always custom-made (a.k.a. bespoke) parts which are not generally available through standard electronic component distribution channels such as us.
With a Google search, I did find the following, which you may find helpful:
Yeah, already got in touch with that company, and they told me that is out of production :pensive_face:
However, i will contact the cluster producer, for get more info. Eventually, will post here for help other people!
Sorry to hear those are out of production. Hopefully you do find an alternate solution, and yes, please post here with what you find out!
My one other thought is to look into the used market, such as ebay or auto salvage yards. Unfortunately, with those, you probably won’t be able to verify whether the part you are purchasing has the same problem you are trying to resolve until you insert it into your dashboard and find out.
