Ifm VNB001 wiring question
------Question for VNB001 Please Put your question below------
I want to confirm the the M12 electrical connections. Our machine has a 24VDC power supply.
First off, would I need a single ended analog input card or a differential analog input card for this vibration sensor?
Pin 1: Wires into our power supply +24VDC.
Pin 2: Analog output (4..20mA) signal. Wired to the PLC analog input (+input 1).
Pin 3: Wires into our power supply 0VDC.
Pin 4: Digital (true/false) output that can be used. Wired to a PLC digital input.
Pin 5: Input for 4-20 mA. Wired to the PLC analog input (-input 1).
