------Question for IM03TS Please Put your question below------
Will someone let me know what socket pin would fit onto this relay?
socket pin will be inserted in to PCB.
thank you,
Juanita
thank you,
Juanita
These parts aren’t made to be socketed, they’re made to be soldered directly to circuit boards.
The leads are pretty thin/weak. If you’re looking for something to socket you should consider something with thicker terminals.
Here is an example:
G2R-2-S DC5(S) Omron Automation and Safety | Relays | DigiKey
Thank you for that, but customer does not want holes that big.
would you be able to see if there is a socket pin that would fit those relays?
thanks
Juanita
I haven’t been able to find anything that would work with those.
If we had anything it would likely be in this category: PC Pin Receptacles, Socket Connectors | Terminals | Electronic Components Distributor DigiKey
