Increase daily Limit
Dear Sir/Madam,
Good day.
My name is Shashank, and I am working as a Component Engineer at Kaynes Technology. I support both the engineering and procurement teams in managing component data.
As part of this effort, I have developed an application using the Digi-Key API to streamline our workflow. However, I am currently facing an issue where the system processes only around 500 MPN (Manufacturer Part Number) records, instead of the required 30,000. This limitation is impacting our operations significantly.
I kindly request your assistance in resolving this issue. Please let me know if you require any additional details, including the API key or technical information.
Your support in this matter would be greatly appreciated.
Thank you for your time and consideration.
Hello @shashank.c
Welcome to the community!
Sorry, large‑scale data export is not a service we provide at this time. However, you can reduce the dataset and identify the exact active parts by removing obsolete components and using the available filter options to narrow down your results.
For my API is there any possibility to increase the limit ? Can you please connect to API development team regarding this
For API questions and issues you will need to create a ticket through the DigiKey API Solutions Dev site.
For the standard APIs, a customer is limited to 1000 searches per day. Larger amounts are available but must be approved by an appropriate sales manager.
https://www.digikey.com/en/resources/api-solutions-faqs
Please submit a ticket thru Contact Us at the bottom of the page.
Best regards,
