Industrial Ethernet cable demands more attention than simply looking at the CAT rating. This engineering brief examines two seemingly similar cables from LAPP. We will compare the physical cable construction as well as select specifications. The single most important lesson is to mentally associate the minimum bend radius specification with the total number of cycles applied to continuous-flex cable.
Featured Products
Two CAT 6A cables are examined. For convenience, we will refer to them by their intended application and the material used for the outer green jacket.
- LAPP 2170464: Fixed-PVC
- LAPP 2170484: Flex-PUR
Key Takeaways
- Cables are application specific: Similar looking cables can have radically different internal construction.
- Design conservatively. Contrary to expectations, a cable designed for continuous-flex applications may have a larger minimum bend radius when compared to a fixed installation cable. This reflects the difference between a single bend during installation vs a million bends for the lifecycle of the flexible cable.
- PUR (polyurethane) and PVC (polyvinyl chloride) are jacket materials. They do not imply flexibility criteria. The featured cables were chosen to maximize the differences between otherwise similar looking cables.
Difficulty:
Student — difficulty levels explained
Last update: 02 Nov 2026
Figure 1: Side by side image of the LAPP cables after the outer shield and green jacket have been removed.
Tech Tip: Close inspection of Figure 1 reveals that the expected white-with-X colored stripe wires are all white. This requires additional vigilance on the part of the RJ45 cable end installer. Each of the four white wires must be physically identified prior to installation. Failure to do so could result in crossing of wires with the wrong partner. Note that the internal spacer in the flex-PUR simplifies the wire pair identification.
Essential Vocabulary
- The term continuous-flex implies a cable designed to operate in a drag chain. These cables are designed to withstand millions of mechanical cycles provided the minimum bend radius specification is observed along with other LAPP specified conditions that are outside the scope of this article.
- The PVC and PUR jacket material are not inherently tied to the terms fixed or continuous-flex. Instead, they are the types of cable I chose for demonstration purposes. Note that PUR is described as abrasion resistant. This distinction is reflected in the effort it takes to remove the outer jacket as outlined in this article.
Photographic Comparison of the Cables
We begin with a series of pictures to show the differences between the cables’ internal construction.
Outer Jacket Removed
Figure 2 shows the two cables with the outer jacket removed. Both cables have a clothlike wrap over the shield. It is continuous for the fixed-PVC while the flex-PUR has spiraled wrapping with about 50 % coverage.
Figure 2: Outer jacket removed: PVC top, PUR bottom.
Tech Tip: Observe that the jacket in Figure 2 has been scored twice. This was done to aid in installation of the RJ-45 cable end. Refer to this article for construction of a similar LAPP cable.
Braided Shield Comparison
A comparison of the outer shields is shown in Figure 3. I was surprised to see that the density (cross-hatch per square inch) was noticeably higher in the flex-PUR. Like every other construction detail in the flex-PUR cable, I assume this was done to increase flexibility and to provide long-term performance as the cable is subject to several million flex events.
Figure 3: Comparison of the braided shield.
Outer Shield Removed
Removal of the shield reveals another surprising design difference as shown in Figure 4. Instead of encountering the individually-shielded twisted pair, we find a clothlike covering on flex-PUR. When the cable flexes this cloth appears to provide a glide surface isolating the braided shield and the individually-shielded twisted pair.
Figure 4: The flex-PUR contains a clothlike covering under the braided shield.
Exposing the Twisted Pairs
Returning to Figure 1 we see a considerable difference between the cable types.
- The flex-PUR uses stranded conductors while the fixed-PVC uses solid core conductors.
- The flex-PUR contains a central white divider to mechanically isolate the individually-shielded twisted pairs from contacting each other. The relationship between the core and pairs is shown in Figure 5.
- The pitch of the flex-PUR twist is reduced. In Figure 1 we can see the difference in the green pair for each cable.
Once again, I assume that these measures are used to increase the flexibility of the cable. Like the cloth covering in Figure 4, the stranded conductors along with the white central core allow the individually-shielded twisted pairs to move relative to each other with minimal abrasion. This is especially important in twisted-pair cables as the pairs focus the abrasion into specific areas.
Figure 5: View of the cable construction from the LAPP datasheet.
Jacket Specifications
As previously noted, LAPP offers cables with outer jackets composed of both PVC and PUR. Cables are also available in FRNC. As an example, consider the datasheet for the 2170464 which states:
Available with robust PVC outer jacket, abrasion-resistant PUR outer jacket or halogen free FRNC outer jacket.
Flexibility Specifications
On initial inspection the featured cables have a similar look and feel. As demonstrated above, the internal construction is very different. Ignoring that for a moment, we can immediately tell the cables apart by bending them as shown in Figure 6.
Observe that the fixed-PVC holds its bent position. This could be a simple property associated with the eight solid wire conductors. It could also be caused by internal elements binding together. By my estimation, the LAPP engineers have expended considerable effort to allow the flex-PUR internal elements to move relative to each other with minimal abrasion.
Figure 6: Comparison of LAPP cables after being bent. The continuous flex cable springs back.
Bend Radius
The bend radius for the fixed-PVC is very simple.
Minimum bending radius, stationary 10 x outer diameter
Ironically, the bend radius for the flex-PUR is larger.
Minimum bending radius, dynamic continuously flexing 15 x outer diameter
This seems like a contradiction as the flex cable is, well, more flexible, and should have a tighter bend radius.
Look closer.
The 15 x bend radius is associated with a second number in the LAPP datasheet.
Maximum bending cycles 2,500,000
With an apples-to-apples comparison, the flex-PUR may be used in a stationary application with a bend radius of 8 x the outer diameter.
Tech Tip: Suppose the cable is used for communication between a panel mounted HMI and a PLC mounted deep within the panel. As a general rule, the wires leading to the HMI should be run in parallel along the length of the panel hinge. This minimizes the total movement applied to any individual section of cable.
For example, let’s assume a hinge length of two feet. That flex is a gentle twisting (torsion) motion across the length of the hinge. Contrast this with a wire run perpendicular to the hinge. We now have a localized bending motion that is applied to a few inches of the wire. The actual bend radius is dependent on the position of the cable management system.
Actually, this raises a different question as the drag chain cable is rated for bending and not necessarily torsion. Hence, the conservative recommendation to run the cable along the length of the panel hinge. Contact the OEM for additional guidance.
Parting Thoughts:
This makes a tremendous difference in how we think about the cable. We are tempted to place the flex-PUR into a tight drag chain. In fact, it feels natural to do so. However, for reliable long-term equipment operation we are reminded to use conservative numbers. That 2.5 million number is associated with the 15 x outer diameter.
About This Author
