We are evaluating your IoT SIM products for use with our MG5 IoT Gateway, which supports LTE-M and NB-IoT connectivity. The gateway will mainly interface with door sensors and demands continuous data transmission to support real-time monitoring.
All SIM cards will be used exclusively within Hong Kong; there will be no international data traffic. Final quantities will be confirmed after our testing cycle.
Would you be able to share the detailed product specifications and any relevant supporting materials? Thanks for your support.
Welcome to the DigiKey TechForum. Take a look at DigiKey part 4412-4573326590334-ND as a possible option for your application. Here is the datasheet and quick start guide for reference materials.
Could you please clarify the data pricing structure? Is it charged based on actual data usage (pay-as-you-go) or do you offer fixed monthly data packages?
We would appreciate your recommendation. Thank you.
