------Question for 202A111-25/86-0 Please Put your question below------
Can I use p/n 202A111-25-0 in place of 202A111-25/86-0
Greetings,
The part number breakdown found on page two of the product drawing indicates that the /86 specifies an adhesive lining, which would contribute to the sealing and mechanical properties of the assembly in which the product is used.
It would be up to you to decide if substitution of an otherwise identical product lacking this adhesive lining is acceptable for the purposes of your application.
