------Question for G0413A Please Put your question below------
We require a latching solenoid or bistable solenoid and we would like confirmation that this product G0413A does as follows.
It has two stable positions (in and out).
It stays in its last position when power is removed.
Reversing the polarity changes which position it moves to.
It makes a mechanical click as it changes state.
When power is applied, the actuator moves to the extended (out) position.
When power is removed, it remains in the extended position because it is held by a permanent magnet.
The actuator produces a distinct click each time it changes between the two positions.
The direction of movement depends on the polarity of the applied voltage.
If positive is connected to positive and negative to negative, applying power moves the actuator to the extended (out) position.
If the polarity is reversed (positive to negative and negative to positive), applying power moves the actuator back to the retracted (in) position.
By reversing the polarity, you can electrically control movement in both directions—extending and retracting the actuator.
