I need to model the ISOBAR12 ULTRA power supply in some CAD. The dimensions provided in the documentation are not quite specific enough, though, they only provide the overall dimensions. I need to know things like the mounting hole diameters, the flange dimensions, and the outlet placement. A CAD file of the part would be most helpful, but even having those dimension details would help. Please let me know if additional mechanical information can be provided for this product.
I have reached out to Eaton Tripplite to see if they can provide a CAD model for the ISOBAR12 ULTRA. As soon as I have response I will follow up with you.
Just an FYI that I am still awaiting response from the manufacturer but I have been requesting updates, the latest as of today. As soon as I have a response I will follow up with you.
Hello smurph16,
Below is the what the MFG responded with:
"Thank you for contacting Eaton’s Technical Support Department and for your patience with this matter. We appreciate you trusting us with your power protection or connectivity needs.
At this time, the only item available would be a Visio Stencil that can be found at the following link:
