J1031C24VDC.20S pinout
------Question for J1031C24VDC.20S Please Put your question below------
The datasheet in DigiKey page shows the pinout of this component to be the following
so I thought that the top left pin would be NC and bottom left pin NO. However, when I received these components, they are exactly the opposite. The datasheet in DigiKey page should be updated.
The datasheet shows the bottom view of the pinout as noted in the datasheet.
The datasheet is controlled by the supplier, not DigiKey.
Ohhhhh! That explains it! Thank you!
