Japan MIC (Giteki) certification status for SparkFun 24540 / Acconeer XM125
I am considering purchasing SparkFun 24540 (DigiKey part number 1568-24540-ND) for use in Japan.
  1. Do you have any information on whether this board, or the Acconeer XM125 module on it, is covered by Japan’s MIC radio certification (Giteki / Construction Design Certification)?
  2. The A121 sensor itself appears to hold Japanese certification number 005-103273. Is there any manufacturer information on whether this certification applies to the XM125 module as mounted on this board?
  3. Could you also tell me the current stock status and estimated delivery time to Japan?
Thank you.------Question for 24540 Please Put your question below------
Hello @zenmurmur
I have reached out to SparkFun Electronics to see what information they can provide on Japan’s MIC (Giteki) certification for this board.
The XM125 datasheet (page 19) and the A121 datasheet (pages 22-28) list only ETSI and FCC approvals, with no mention of Japanese certification or number 005-103273.
@jon_11475
Hi Jon,
Thank you for reaching out to SparkFun on my behalf. I’d appreciate it if you could share their response once you hear back.
For reference, I found the certification number 005-103273 on [source]. I’d like to confirm whether it applies to this board.
Best regards,
Kenichi
Hello @zenmurmur
Acconeer, the XM125 module manufacturer, confirmed that Japanese certification number 005-103273 applies to the XM125 module.
SparkFun advised that they have no additional certification documentation for the board, and that their team understands a board built on a compliant module should also be compliant.
Best regards.
Hi @jon_11475,
Thank you for following up with both Acconeer and SparkFun. Getting confirmation directly from the manufacturer that certification number 005-103273 covers the XM125 module is very helpful.
I also appreciate you passing on SparkFun’s view on the board. I’ll take that into account as I plan the next steps.
Thanks again for your time and help.
Best regards,
zenmurmur
