dzhou
November 18, 2020, 5:30pm
1
Hi Robert,
I installed JDK11 and jetty9. When I start (start.jar is under /opt/jetty):
java -jar start.jar
I got run time error. The log file i attached.
I am aware that java is out of the scope of your support. Certainly I would greatly appreciate your help.
David
hs_err_pid13472.log (30.9 KB)
dzhou
November 18, 2020, 5:41pm
2
Hi Robert,
From the error message on the console:
Could not load hsdis-arm.so; library not loadable; PrintAssembly is disabled
Aborted
it seems related to the hsdis-arm.so lib file;
Thank you,
David
dzhou
November 18, 2020, 6:15pm
3
Hi Robert,
I started java with command option -XX:-AssumeMP, the run-time crash disappeared.
$ java -XX:-AssumeMP -jar …/start.jar
Best Regards,
David
It looks like in JAVA 12, this will not be required anymore…
https://bugs.openjdk.java.net/browse/JDK-8188079
Regards,
dzhou
November 18, 2020, 6:58pm
5
Hi Robert,
I guess it was in JDK8, then deprecated in JDK11, then fixed in JDK12.
I still have installation issues with JRE. I am going to re-flash the board, then install it from fresh, and send you the error messages for you to take a look. Thank you for your help!
Best Regards,
David
What base image are you using?
debian@bbb-pwr01-ser09:~$ sudo apt install default-jdk
Requires:
0 upgraded, 133 newly installed, 0 to remove and 1 not upgraded.
Need to get 273 MB of archives.
After this operation, 812 MB of additional disk space will be used.
Do you want to continue? [Y/n]
So almost 1GB of free space…
Regards,
dzhou
November 18, 2020, 7:11pm
7
Hi Robert,
Debian 10, Buster Release (2019-07-07). It is pre-built image from BBB web site. I did exactly that way. Give me sometime, as I said I will install it from fresh, so it will make you easier to spot the problem.
Best Regards,
David
dzhou:
and how much free space is available in the that old image?
and just triggered the same error:
Adding debian:ePKI_Root_Certification_Authority.pem
Adding debian:XRamp_Global_CA_Root.pem
# A fatal error has been detected by the Java Runtime Environment:
# SIGILL (0x4) at pc=0xb40c6760, pid=2739, tid=2747
# JRE version: OpenJDK Runtime Environment (11.0.9+11) (build 11.0.9+11-post-Debian-1deb10u1)
# Java VM: OpenJDK Server VM (11.0.9+11-post-Debian-1deb10u1, mixed mode, serial gc, linux-)
# Problematic frame:
# J 46 c2 sun.security.provider.X509Factory.readOneBlock(Ljava/io/InputStream;)[B java.base@11.0.9 (447 bytes) @ 0xb40c6760 [0
xb40c66e0+0x00000080]
# No core dump will be written. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starti
ng Java again
# An error report file with more information is saved as:
# //hs_err_pid2739.log
# If you would like to submit a bug report, please visit:
# https://bugs.debian.org/openjdk-11
/var/lib/dpkg/info/ca-certificates-java.postinst: line 88: 2737 Done find /etc/ssl/certs -name \*.pem
2738 | while read filename; do
alias=$(basename $filename .pem | tr A-Z a-z | tr -cs a-z0-9 _); alias=${alias%*_}; if [ -n "$FIXOLD" ]; then
echo "-${alias}"; echo "-${alias}_pem";
fi; echo "+${filename}";
done
2739 Aborted | java -Xmx64m -jar $JAR -storepass "$storepass"
dpkg: error processing package ca-certificates-java (--configure):
installed ca-certificates-java package post-installation script subprocess returned error exit status 134
Setting up default-jdk (2:1.11-71) ...
Processing triggers for systemd (241-7~deb10u4rcnee0~buster+20200509) ...
Processing triggers for man-db (2.8.5-2) ...
Processing triggers for ca-certificates (20200601~deb10u1) ...
Updating certificates in /etc/ssl/certs...
0 added, 0 removed; done.
Running hooks in /etc/ca-certificates/update.d...
done.
done.
Processing triggers for mime-support (3.62) ...
Processing triggers for libglib2.0-0:armhf (2.58.3-2+deb10u2) ...
Processing triggers for libc-bin (2.28-10) ...
Setting up glib-networking:armhf (2.58.0-2+deb10u2) ...
Setting up libsoup2.4-1:armhf (2.64.2-2) ...
Setting up libsoup-gnome2.4-1:armhf (2.64.2-2) ...
Setting up librest-0.7-0:armhf (0.8.1-1) ...
Setting up libgtk-3-0:armhf (3.24.5-1) ...
Setting up libgtk-3-bin (3.24.5-1) ...
Setting up libatk-wrapper-java-jni:armhf (0.33.3-22) ...
Processing triggers for libgdk-pixbuf2.0-0:armhf (2.38.1+dfsg-1) ...
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
Looks like ca-certificates-java needs the "XX:-AssumeMP " fix…
Bug report here: https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=960153
Regards,
dzhou
November 18, 2020, 7:27pm
9
Hi Rebort,
I am installing into our board with 16G total flash space.
That’s the almost exact error I got.
But the question is how to set XX:-AssumeMP into the installation script?
Best Regards,
David
i posted a response on : https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=960153 not sure how long it’ll take to show up…
Regards,
dzhou
November 18, 2020, 7:35pm
12
The Bug report you posted doesn’t include a resolution.
I found a work-around in my previous thread to mv out the configuration file ( couldn’t remember exact wording).
I am not sure that has no “side-effect”.
The script you posted ( postinst.in ) , I don’t know how run it during installation.
Thank you,
David
dzhou
November 18, 2020, 7:36pm
13
This is the work-around:
sudo mv /var/lib/dpkg/info/ca-certificates-java.postinst /var/lib/dpkg/info/ca-certificates-java.postinst.bac
sudo apt-get purge ca-certificate-java
sudo apt-get install -f
I don’t know it IS a solution. But it will install.
David
Yeap, that’s an active bug report…
Getting Closer:
Do you want to continue? [Y/n] y
Get:1 http://repos.rcn-ee.com/debian buster/main armhf ca-certificates-java all 20190405rcnee0~buster+20201118 [15.8 kB]
Fetched 15.8 kB in 0s (71.2 kB/s)
(Reading database ... 85872 files and directories currently installed.)
Preparing to unpack .../ca-certificates-java_20190405rcnee0~buster+20201118_all.deb ...
Unpacking ca-certificates-java (20190405rcnee0~buster+20201118) over (20190405) ...
Setting up ca-certificates-java (20190405rcnee0~buster+20201118) ...
OpenJDK Server VM warning: Option AssumeMP was deprecated in version 10.0 and will likely be removed in a future release.
Adding debian:ISRG_Root_X1.pem
Adding debian:EC-ACC.pem
Adding debian:GTS_Root_R4.pem
Adding debian:Entrust_Root_Certification_Authority_-_G4.pem
Adding debian:Staat_der_Nederlanden_EV_Root_CA.pem
Adding debian:GeoTrust_Universal_CA_2.pem
Adding debian:Sonera_Class_2_Root_CA.pem
Adding debian:emSign_ECC_Root_CA_-_G3.pem
Adding debian:IdenTrust_Commercial_Root_CA_1.pem
Adding debian:SSL.com_Root_Certification_Authority_RSA.pem
Adding debian:Security_Communication_RootCA2.pem
Adding debian:Entrust.net_Premium_2048_Secure_Server_CA.pem
Adding debian:DigiCert_Global_Root_CA.pem
Adding debian:Staat_der_Nederlanden_Root_CA_-_G2.pem
Adding debian:Certigna.pem
Adding debian:Chambers_of_Commerce_Root_-_2008.pem
Adding debian:TWCA_Root_Certification_Authority.pem
Adding debian:Network_Solutions_Certificate_Authority.pem
Adding debian:Izenpe.com.pem
Adding debian:DigiCert_Global_Root_G3.pem
Adding debian:AffirmTrust_Premium.pem
Adding debian:D-TRUST_Root_Class_3_CA_2_2009.pem
Adding debian:SSL.com_EV_Root_Certification_Authority_ECC.pem
Adding debian:Secure_Global_CA.pem
Adding debian:Cybertrust_Global_Root.pem
Adding debian:OISTE_WISeKey_Global_Root_GC_CA.pem
Adding debian:GlobalSign_ECC_Root_CA_-_R4.pem
Adding debian:CFCA_EV_ROOT.pem
Adding debian:QuoVadis_Root_CA_2.pem
Adding debian:Entrust_Root_Certification_Authority_-_EC1.pem
Adding debian:Global_Chambersign_Root_-_2008.pem
Adding debian:GlobalSign_Root_CA_-_R2.pem
Adding debian:QuoVadis_Root_CA_1_G3.pem
Adding debian:SecureSign_RootCA11.pem
Adding debian:Autoridad_de_Certificacion_Firmaprofesional_CIF_A62634068.pem
Adding debian:Certum_Trusted_Network_CA.pem
Adding debian:GlobalSign_Root_CA.pem
Adding debian:Comodo_AAA_Services_root.pem
Adding debian:GDCA_TrustAUTH_R5_ROOT.pem
Adding debian:DST_Root_CA_X3.pem
Adding debian:GlobalSign_ECC_Root_CA_-_R5.pem
Adding debian:GTS_Root_R2.pem
Adding debian:GlobalSign_Root_CA_-_R6.pem
Adding debian:Baltimore_CyberTrust_Root.pem
Adding debian:QuoVadis_Root_CA.pem
Adding debian:Go_Daddy_Root_Certificate_Authority_-_G2.pem
Adding debian:Entrust_Root_Certification_Authority_-_G2.pem
Adding debian:DigiCert_Trusted_Root_G4.pem
Adding debian:AffirmTrust_Premium_ECC.pem
Adding debian:UCA_Global_G2_Root.pem
Adding debian:Starfield_Root_Certificate_Authority_-_G2.pem
Adding debian:COMODO_ECC_Certification_Authority.pem
Adding debian:SSL.com_EV_Root_Certification_Authority_RSA_R2.pem
Adding debian:SecureTrust_CA.pem
Adding debian:D-TRUST_Root_Class_3_CA_2_EV_2009.pem
Adding debian:T-TeleSec_GlobalRoot_Class_3.pem
Adding debian:COMODO_Certification_Authority.pem
Adding debian:TrustCor_RootCert_CA-1.pem
Adding debian:TrustCor_RootCert_CA-2.pem
Adding debian:Verisign_Class_3_Public_Primary_Certification_Authority_-_G3.pem
Adding debian:Hongkong_Post_Root_CA_3.pem
Adding debian:emSign_Root_CA_-_C1.pem
Adding debian:QuoVadis_Root_CA_3_G3.pem
Adding debian:TUBITAK_Kamu_SM_SSL_Kok_Sertifikasi_-_Surum_1.pem
Adding debian:LuxTrust_Global_Root_2.pem
Adding debian:Entrust_Root_Certification_Authority.pem
Adding debian:TWCA_Global_Root_CA.pem
Adding debian:NetLock_Arany_=Class_Gold=_Főtanúsítvány.pem
Adding debian:SwissSign_Gold_CA_-_G2.pem
Adding debian:GTS_Root_R3.pem
Adding debian:SZAFIR_ROOT_CA2.pem
Adding debian:TrustCor_ECA-1.pem
Adding debian:Hongkong_Post_Root_CA_1.pem
Adding debian:T-TeleSec_GlobalRoot_Class_2.pem
Adding debian:Buypass_Class_3_Root_CA.pem
Adding debian:DigiCert_Assured_ID_Root_G2.pem
Adding debian:SSL.com_Root_Certification_Authority_ECC.pem
Adding debian:Amazon_Root_CA_4.pem
Adding debian:certSIGN_ROOT_CA.pem
Adding debian:SwissSign_Silver_CA_-_G2.pem
Adding debian:OISTE_WISeKey_Global_Root_GA_CA.pem
Adding debian:GTS_Root_R1.pem
Adding debian:Microsec_e-Szigno_Root_CA_2009.pem
Adding debian:TeliaSonera_Root_CA_v1.pem
Adding debian:Hellenic_Academic_and_Research_Institutions_ECC_RootCA_2015.pem
Adding debian:USERTrust_ECC_Certification_Authority.pem
Adding debian:Amazon_Root_CA_3.pem
Adding debian:Security_Communication_Root_CA.pem
Adding debian:CA_Disig_Root_R2.pem
Adding debian:AC_RAIZ_FNMT-RCM.pem
Adding debian:Certum_Trusted_Network_CA_2.pem
Adding debian:Certigna_Root_CA.pem
Adding debian:QuoVadis_Root_CA_2_G3.pem
Adding debian:AffirmTrust_Networking.pem
Adding debian:Actalis_Authentication_Root_CA.pem
Adding debian:Atos_TrustedRoot_2011.pem
Adding debian:Starfield_Services_Root_Certificate_Authority_-_G2.pem
Adding debian:IdenTrust_Public_Sector_Root_CA_1.pem
Adding debian:Trustis_FPS_Root_CA.pem
Adding debian:Hellenic_Academic_and_Research_Institutions_RootCA_2011.pem
Adding debian:UCA_Extended_Validation_Root.pem
Adding debian:COMODO_RSA_Certification_Authority.pem
Adding debian:Buypass_Class_2_Root_CA.pem
Adding debian:emSign_ECC_Root_CA_-_C3.pem
Adding debian:Hellenic_Academic_and_Research_Institutions_RootCA_2015.pem
Adding debian:DigiCert_Assured_ID_Root_G3.pem
Adding debian:QuoVadis_Root_CA_3.pem
Adding debian:DigiCert_High_Assurance_EV_Root_CA.pem
Adding debian:DigiCert_Assured_ID_Root_CA.pem
Adding debian:DigiCert_Global_Root_G2.pem
Adding debian:Starfield_Class_2_CA.pem
Adding debian:Amazon_Root_CA_1.pem
Adding debian:emSign_Root_CA_-_G1.pem
Adding debian:OISTE_WISeKey_Global_Root_GB_CA.pem
Adding debian:Go_Daddy_Class_2_CA.pem
Adding debian:ssl-cert-snakeoil.pem
Adding debian:USERTrust_RSA_Certification_Authority.pem
Adding debian:GlobalSign_Root_CA_-_R3.pem
Adding debian:Amazon_Root_CA_2.pem
Adding debian:Staat_der_Nederlanden_Root_CA_-_G3.pem
Adding debian:EE_Certification_Centre_Root_CA.pem
Adding debian:AffirmTrust_Commercial.pem
Adding debian:E-Tugra_Certification_Authority.pem
Adding debian:ACCVRAIZ1.pem
Adding debian:Taiwan_GRCA.pem
done.
# SIGILL (0x4) at pc=0xb40d8a50, pid=10324, tid=10325
# J 44 c2 java.math.BigInteger.stripLeadingZeroBytes([BII)[I java.base@11.0.9 (141 bytes) @ 0xb40d8a50 [0xb40d8990+0x000000c0
ing Java again
# /etc/ssl/certs/hs_err_pid10324.log
Aborted
E: /etc/ca-certificates/update.d/jks-keystore exited with code 1.
done.
Regards,
dzhou:
It’s all fixed now…
sudo apt update
sudo apt upgrade
The following packages will be upgraded:
1 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Need to get 15.8 kB of archives.
After this operation, 0 B of additional disk space will be used.
Get:1 http://repos.rcn-ee.com/debian buster/main armhf ca-certificates-java all 20190405rcnee1~buster+20201118 [15.8 kB]
Fetched 15.8 kB in 0s (62.8 kB/s)
Preparing to unpack .../ca-certificates-java_20190405rcnee1~buster+20201118_all.deb ...
Unpacking ca-certificates-java (20190405rcnee1~buster+20201118) over (20190405rcnee0~buster+20201118) ...
Setting up ca-certificates-java (20190405rcnee1~buster+20201118) ...
Installing new version of config file /etc/ca-certificates/update.d/jks-keystore ...
done.
done.
With this fix:
diff --git a/debian/jks-keystore.hook.in b/debian/jks-keystore.hook.in
index d4a67d0..5bdc65b 100644
--- a/debian/jks-keystore.hook.in
+++ b/debian/jks-keystore.hook.in
@@ -79,7 +79,7 @@ do_cleanup()
fi
-if java -Xmx64m -jar $JAR -storepass "$storepass"; then
+if java -Xmx64m -XX:-AssumeMP -jar $JAR -storepass "$storepass"; then
do_cleanup
else
do_cleanup
diff --git a/debian/postinst.in b/debian/postinst.in
index bc78c6e..30d0846 100644
--- a/debian/postinst.in
+++ b/debian/postinst.in
@@ -98,7 +98,7 @@ first_install()
# Forcibly remove diginotar cert (LP: #920758)
echo -e "-diginotar_root_ca\n-diginotar_root_ca_pem" | \
- java -Xmx64m -jar $JAR -storepass "$storepass"
+ java -Xmx64m -XX:-AssumeMP -jar $JAR -storepass "$storepass"
fi
find /etc/ssl/certs -name \*.pem | \
@@ -111,7 +111,7 @@ first_install()
fi
echo "+${filename}"
done | \
echo "done."
Regards,
dzhou
November 18, 2020, 9:09pm
16
Hi Robert,
Thank you very much for the fixing. I have installed default-jre (11) without error.
Best Regards,
David
Tips to Fix a Runtime Error
Restart the computer.
Update the program to its latest version.
Fully delete the program, and then reinstall it.
Install the latest Microsoft Visual C++ Redistributable package.
Use SFC scannow to repair corrupted Windows files.
Run System Restore to return your computer to a previous state.
Greeting,
Rachel Gomez
Thanks for sharing, Rachel.
This issue was fixed in Debian’s java package. The device in question is a BeagleBone Black, running Debian.
Closing thread, if you are seeing a similar issue please create a new thread.
