------Question for 3001938 Please Put
your question below------
what is the part number
for the terminal joiner # listed
above?
above?
Hello mike14,
Welcome to the TechForum. I’m not entirely sure what you are looking for with the phrasing of your question. If you are looking for the DigiKey part number for 3001938, that would be 277-2339-ND. If not, are you referring to the bridges or the fuses for this part? They are listed in the datasheet, however there are multiple options for what exactly you need. For example, part number 277-3669-ND is used to bridge two of these blocks together and part number 277-3767-ND is the fuse used in the center of the block. In your original question, can you clarify any more on what you are looking for?
Please refer bridges and fuse section on the datasheet HERE.
Best regards,
Jon
Thank you for your help. I did not see the jumpers listed on the data sheet the first time I looked at it. I am ordering the correct ones now.
Have a great day!
