Knowles FG C05 microphone cabling, P07 replacement
------Question for FG-23329-C05 Please Put your question below------
I’m looking to use the C05 as a replacement for the old P07 mics which are now discontinued. These are apparently a direct replacement but I’m trying to confirm how theyre wired. The old P07’s had wiring to the mic already and this could be soldered on the other end to a connector. It looks like these new ones will require their own wiring. If its known whether they come with wiring or not it would be very useful to know, else if theres an alternative that uses the C05 mic which is pre-wired that would also be good to know. Thanks.
Hello @CSharp13
Welcome to DigiKey’s TechForum,
Technical specs for part number FG-23329-C05
For comparison the datasheet for the pre-wired P07 option.
