Aqui mostraremos como se utiliza Zephyr en la plataforma NXP MCUXpresso Experiencia de Desarrollo MCXN947
El siguiente diagrama ilustra el NXP MCUXpresso Experiencia de Desarrollo MCXN947,
Primero se procede a instalar Zephyr como se muestra en el articulo anterior. Se procede a construir el siguiente codigo bien sencillo y elemental,
* Copyright (c) 2025 Intel Corporation
* SPDX-License-Identifier: Apache-2.0
#include <zephyr/kernel.h>
#include <zephyr/rtio/rtio.h>
#include <zephyr/logging/log.h>
LOG_MODULE_REGISTER(main, LOG_LEVEL_DBG);
/* Our producer is a timer (interrupt) but could be a thread as well */
struct producer {
struct mpsc io_q;
/* Our producer function, could be done in a thread or interrupt, here
* we are producing cycle count values from a timer interrupt.
static void producer_periodic(struct k_timer *timer)
struct producer *p = timer->user_data;
LOG_INF("producer %p trigger", (void *)p);
struct mpsc_node *n = mpsc_pop(&p->io_q);
if (n == NULL) {
LOG_WRN("producer overflowed consumers");
return;
struct rtio_iodev_sqe *iodev_sqe = CONTAINER_OF(n, struct rtio_iodev_sqe, q);
/* Only accept read/rx requests */
if (iodev_sqe->sqe.op != RTIO_OP_RX) {
rtio_iodev_sqe_err(iodev_sqe, -EINVAL);
return;
/* Get the rx buffer with a minimum/maximum size pair to fill with the current time */
uint8_t *buf = NULL;
uint32_t buf_len = 0;
int rc = rtio_sqe_rx_buf(iodev_sqe, sizeof(uint64_t), sizeof(uint64_t), &buf, &buf_len);
LOG_INF("buf %p, len %u", (void *)buf, buf_len);
if (rc < 0) {
/* buffer wasn't available or too small */
rtio_iodev_sqe_err(iodev_sqe, -ENOMEM);
return;
/* We now have a buffer we can produce data into and then signal back to the consumer */
uint64_t *cycle_count = (uint64_t *)buf;
/* "Produce" a timestamp */
*cycle_count = k_cycle_get_64();
/* Signal read has completed */
rtio_iodev_sqe_ok(iodev_sqe, 0);
/* Accept incoming commands (e.g. read requests), could come from multiple sources
* so the only real safe thing to do here is put it into the lock free queue
static void producer_submit(struct rtio_iodev_sqe *iodev_sqe)
struct mpsc *producer_ioq = iodev_sqe->sqe.iodev->data;
mpsc_push(producer_ioq, &iodev_sqe->q);
K_TIMER_DEFINE(producer_tmr, producer_periodic, NULL);
static struct producer producer_data;
const struct rtio_iodev_api producer_api = {.submit = producer_submit};
/* Setup our i/o device, akin to a file handle we can read from */
RTIO_IODEV_DEFINE(producer_iodev, &producer_api, &producer_data);
/* Setup our pair of queues for our consumer, with 1 submission and 1 completion available */
RTIO_DEFINE(rconsumer, 1, 1);
int consumer_loop(struct rtio *consumer, struct rtio_iodev *producer)
/* We can share memory with kernel space without any work, to share
* between usermode threads we'd need a k_mem_partition added to
* both domains instead
uint64_t cycle_count;
/* Our read submission and completion pair */
struct rtio_sqe read_sqe;
struct rtio_cqe read_cqe;
struct rtio_sqe *read_sqe_handle;
/* Helper that sets up the submission to be a read request, reading *directly*
* into the given buffer pointer without copying
rtio_sqe_prep_read(&read_sqe, producer, RTIO_PRIO_NORM, (uint8_t *)&cycle_count,
sizeof(cycle_count), NULL);
/* We can automatically have this read request resubmitted for us */
read_sqe.flags |= RTIO_SQE_MULTISHOT;
/* A syscall to copy the control structure (sqe) into kernel mode, and get a handle out
* so we can cancel it later if we want
rtio_sqe_copy_in_get_handles(consumer, &read_sqe, &read_sqe_handle, 1);
/* A syscall to submit the queued up requests (there could be many) to all iodevs */
rtio_submit(consumer, 0);
/* A consumer loop that waits for read completions in a single syscall
* This never ends but to end the loop we'd cancel the requests to read.
* NOTE: There could be multiple read requests out to multiple producers we could
* be waiting on!
while (true) {
/* A syscall to consume a completion, waiting forever for it to arrive */
rtio_cqe_copy_out(consumer, &read_cqe, 1, K_FOREVER);
/* The read has been completed, and its safe to read the value until
* we attach and submit a request to read into it again
LOG_INF("read result %d, cycle count is %llu", read_cqe.result, cycle_count);
return 0;
int main(void)
/* init stuff */
mpsc_init(&producer_data.io_q);
producer_tmr.user_data = &producer_data;
/* Start our producer task (timer interrupt based) */
k_timer_start(&producer_tmr, K_MSEC(100), K_MSEC(100));
/* We can enter usermode here with a little work to setup k_objects for the iodev
* and struct rtio context
* E.g.
* k_object_access_grant(&producer, k_current_get());
* k_object_access_grant(&consumer, k_current_get());
* k_thread_user_mode_enter(consumer_loop, &producer, &consumer, NULL);
return consumer_loop(&rconsumer, &producer_iodev);
desde el ambiente virtual,
(venv) DigiKey_Coffee_Cup #west build -b frdm_mcxn947/mcxn947/cpu0 samples/subsys/rtio/producer_consumer/
- west build: generating a build system
Loading Zephyr default modules (Zephyr base).
En el terminal de minicom debe de observarse lo siguiente luego de west flash
Welcome to minicom 2.10
OPTIONS: I18n
Port /dev/ttyACM0, 23:26:43 [U]
Press CTRL-A Z for help on special keys
I: producer 0x30000448 trigger
I: buf 0x300011f8, len 8
I: read result 0, cycle count is 586493777
I: read result 0, cycle count is 601493165
I: read result 0, cycle count is 616492655
I: read result 0, cycle count is 631493573
I: read result 0, cycle count is 646493675
I: read result 0, cycle count is 661493709
I: read result 0, cycle count is 676493369
I: read result 0, cycle count is 691493437
Hemos completado este demo de un patron productor y consumidor usando RTIO con K-timer creando los ciclos de conteo correspondientes cuando se realiza el ISR en este caso. La plataforma bien conocida NXP MCUXpresso Experiencia de Desarrollo MCXN947 es de bajo costo pero tiene muchas aplicaciones en diversas areas, y está disponible en DigiKey. Mantenganse sintonizado para nuestro próximo artículo.
Que tenga un buen día!
