La plataforma NXP MCUXpresso Experiencia de Desarrollo MCXN947 (Parte 8)
Aqui mostraremos como se utiliza Zephyr en la plataforma NXP MCUXpresso Experiencia de Desarrollo MCXN947
Primero se procede a instalar Zephyr como se muestra en el articulo anterior. Se procede a construir el siguiente codigo que implementa un demo medida de temperatura del sensor,
 * Copyright (c) 2016 ARM Ltd.
 * Copyright (c) 2023 FTP Technologies
 * Copyright (c) 2023 Daniel DeGrasse <daniel@degrasse.com>
 * SPDX-License-Identifier: Apache-2.0
#include <zephyr/kernel.h>
#include <zephyr/drivers/sensor.h>
#include <stdio.h>
static double high_temp;
static double low_temp;
int read_temperature(const struct device *dev, struct sensor_value *val)
	int ret;
	ret = sensor_sample_fetch_chan(dev, SENSOR_CHAN_AMBIENT_TEMP);
	if (ret < 0) {
		printf("Could not fetch temperature: %d\n", ret);
		return ret;
	ret = sensor_channel_get(dev, SENSOR_CHAN_AMBIENT_TEMP, val);
	if (ret < 0) {
		printf("Could not get temperature: %d\n", ret);
	return ret;
void temp_alert_handler(const struct device *dev, const struct sensor_trigger *trig)
	int ret;
	struct sensor_value value;
	double temp;
	/* Read sensor value */
	ret = read_temperature(dev, &value);
	if (ret < 0) {
		printf("Reading temperature failed: %d\n", ret);
		return;
	temp = sensor_value_to_double(&value);
	if (temp <= low_temp) {
		printf("Temperature below threshold: %0.1f°C\n", temp);
	} else if (temp >= high_temp) {
		printf("Temperature above threshold: %0.1f°C\n", temp);
	} else {
		printf("Error: temperature alert triggered without valid condition\n");
int main(void)
	const struct device *const dev = DEVICE_DT_GET(DT_ALIAS(ambient_temp0));
	double temp;
	int ret;
	const struct sensor_trigger trig = {
		.chan = SENSOR_CHAN_AMBIENT_TEMP,
		.type = SENSOR_TRIG_THRESHOLD,
	printf("Thermometer Example (%s)\n", CONFIG_ARCH);
	if (!device_is_ready(dev)) {
		printf("Device %s is not ready\n", dev->name);
		return 0;
	printf("Temperature device is %p, name is %s\n", dev, dev->name);
	/* First, fetch a sensor sample to use for sensor thresholds */
	if (ret != 0) {
		printf("Failed to read temperature: %d\n", ret);
		return ret;
	/* Set thresholds to +0.5 and +1.5 °C from ambient */
	low_temp = temp + 0.5;
	ret = sensor_value_from_double(&value, low_temp);
	if (ret != 0) {
		printf("Failed to convert low threshold to sensor value: %d\n", ret);
		return ret;
	ret = sensor_attr_set(dev, SENSOR_CHAN_AMBIENT_TEMP,
			      SENSOR_ATTR_LOWER_THRESH, &value);
	if (ret == 0) {
		/* This sensor supports threshold triggers */
		printf("Set temperature lower limit to %0.1f°C\n", low_temp);
	high_temp = temp + 1.5;
	ret = sensor_value_from_double(&value, high_temp);
	if (ret != 0) {
		return ret;
			      SENSOR_ATTR_UPPER_THRESH, &value);
	if (ret == 0) {
		printf("Set temperature upper limit to %0.1f°C\n", high_temp);
	ret = sensor_trigger_set(dev, &trig, temp_alert_handler);
	if (ret == 0) {
		printf("Enabled sensor threshold triggers\n");
	while (1) {
		if (ret != 0) {
			break;
		printf("Temperature is %0.1lf°C\n", sensor_value_to_double(&value));
		k_sleep(K_MSEC(1000));
	return 0;
desde el ambiente virtual,
(venv) DigiKey_Coffee_Cup # west build -b frdm_mcxn947/mcxn947/cpu0 samples/sensor/thermometer/
- west build: generating a build system
Loading Zephyr default modules (Zephyr base).
En el terminal de minicom debe de observarse lo siguiente luego de west flash
elcome to minicom 2.10
OPTIONS: I18n
Port /dev/ttyACM0, 23:58:53 [U]
Press CTRL-A Z for help on special keys
Temperature is 23.1°C
Temperature is 23.4°C
Temperature is 23.0°C
Temperature is 22.9°C
Hemos completado este demo del sensor de temperatura. La plataforma bien conocida NXP MCUXpresso Experiencia de Desarrollo MCXN947 es de bajo costo pero tiene muchas aplicaciones en diversas areas, y está disponible en DigiKey. Mantenganse sintonizado para nuestro próximo artículo.
Que tenga un buen día!
