I am in need of some LED lamps for a broadcast console. Original company moved to produce other things that are more profitable and the secondary supplier of parts stopped a couple of years ago. I measured 5VDC and about 250 MA. I have included a circuit diagram that has the lamp shown in it and the old part number as well. I have uploaded that diagram as well as measurements for lamp itself.. so you get an idea of the package.It seems bidirectional, so I may be way off on the LED part. Or if an LED part would retro fit, that would be fine.
The symbol and measured current flow are indicative of a miniature incandescent lamp, which are nearing obsolescence at this point. Current listings with stock can be found here.
Replacement with some manner of LED may be an option; devices with built-in resistance for direct 5V operation can be found here, or adding another resistance externally to accommodate one of standard type may also be an option, depending on other applicable considerations.
Thank you very much for your response.
I will consider the options you have provided. I would like to source an LED that can work in this environment… because of where it is located, extra resistance is going to hard to add.
