Laptop charger for a tulpar t7 v20.6 help!
Trying to find an fsp charger for a tulpar t7 v20.6 laptop help please . The end is 5.5 x 2.5 mm
Welcome to the community and thank you for your inquiry.
We do not have anything with this voltage with a 2.5mm ID 5.5OD barrel plug.
I’ve never seen a barrel plug that can handle 230 Watts. Usually you see power supplies with that amount of power use 4 pin connectors to share the load.
Humm fsp sent me here to ask even tho it’s branded fsp… this Seams to be the closest one I can find available online i just really wanted an original.
We have an FSP power supply that matches most of those specs, however it has this connector on it:
Oh no its definitely a 1 pin type. Probably because its a Chinese branded laptop
Many times an OEM will work with FSP or another power supply manufacturer to add a specific connection for their product.
