Building a Standalone Offline Music Player Using the MAX32655FTHR — Day 1
Introduction
For this project, I wanted to build a compact, standalone music player rather than another embedded device that depends on a smartphone or an internet connection for its primary functionality.
A huge thanks to Circuit Digest and Digikey for giving me this opportunity
The idea was to combine embedded hardware, audio processing, removable storage, a custom graphical interface, physical controls, and a 3D-printed enclosure into one portable device.
The result is a Japanese Sakura-inspired music player designed around the MAX32655FTHR
development board from Analog Devices.
The central requirement is straightforward: store music locally on a microSD card, browse the available tracks, select a song using physical controls, and listen through a wired headphone output. However, implementing this requires several subsystems to work together correctly.
System architecture
The project is built around the following hardware:
Controller: Analog Devices MAX32655FTHR development board.
Display: 1.9-inch, 170 × 320 ST7789 TFT module connected over SPI.
Storage: Onboard microSD card interface for locally stored music.
Audio: Onboard audio codec and 3.5 mm headphone output.
User input: Physical Select, Left, and Right navigation controls.
Mechanical design: Custom 3D-printed enclosure designed around the board and display.
The MAX32655FTHR was an interesting choice because it brings several useful capabilities together on one development platform. Instead of building a separate audio subsystem and adding a collection of external modules immediately, I could begin by investigating what the board already provides.
Design philosophy
I wanted this device to feel like a dedicated piece of hardware.
That means the user should be able to navigate the music library and control playback without needing to unlock a phone, open an application, or establish an internet connection.
The display uses a Japanese Sakura-inspired visual identity, with a compact layout designed specifically for the small screen. The intention is to keep the interface visually distinctive while remaining readable and practical.
Bluetooth Low Energy is available on the controller, but wireless audio streaming is not part of the initial design. The primary audio path is through wired headphones.
What makes the project interesting?
The challenge is not simply connecting a display or getting a microcontroller to play a file. It is integrating storage, display rendering, input handling, and audio output into one responsive embedded application.
Each subsystem has different timing and resource requirements. Display updates must not interrupt audio playback, file access must be reliable, and physical controls must remain responsive while the device is operating.
Over this seven-part series, I’ll discuss the hardware architecture, display integration, mechanical design, navigation, storage, audio pipeline, and the final assembled device.
#AnalogDevices #MAX32655FTHR #EmbeddedSystems #AudioElectronics #DigiKey
