Hi,
I am trying to find a replacement for an obsolete Graphic Display from a damaged controller. The part number is TE2144CS021, and it appears to no longer be manufactured.
Is there an equivalent part available?
Thanks for any help,
Avi.
Hi,
Avi.
Hello and welcome to the community!
Can you share some photos of the display along with the dimensions and connection?
Hi Jeff,
I don’t know how to upload any images to the forum. However the display is 40mm tall and 29mm across. It’s monochrome with a tape connector at its short side that is 20mm long.
The part number shows TE2144CS021 followed by, VEU068A, 200C1Q002B, TC014SC1U2-03Y. The connection tape shows A1360020-00 02 2143.
It is the display for an electric e-foil hand controller.
My issue is that the controller was left in the sun for a few weeks on a windowsill and the display appears to have failed, replacements are eye wateringly expensive.
Many thanks for any help you can offer, this is clearly not my specialty!
Avi.
Thanks for the information. I found this obsolete display in our system that is part number E2144CS021. Can you verify this is the display you have and if it is we can check for a possible alternate to it.
Hi Steve,
Everything I have looked at suggests that the part number you mention, is the part that I am looking for. If you can find an equivalent part, I would be extremely grateful.
Many thanks,
Avi.
Sorry, im not finding a part with those specs.
Thanks for verifying, I checked and wasn’t able to find an equivalent to offer for this display.
Thanks for looking.
