I’m using a Waveshare ESP32-S3-Touch-LCD-1.46B with a 2×10, 1.27 mm male header.
I found DigiKey part DR127D254P20F-ND, but its 2.54 mm side has male pins. I’m looking for a similar compact, preassembled adapter with:
- ESP32 side: 2×10, 1.27 mm female socket
- Output side: 2×10, 2.54 mm female sockets
- 20 positions total
- Compatible with standard male Dupont jumper wires
Essentially, I need a 1.27 mm female-to-2.54 mm female pitch adapter without long male pins sticking out.
Does DigiKey carry this exact configuration or a compatible alternative? A bottom-entry or pass-through design may also work if it accepts standard 2.54 mm male jumper wires.
Thank you.
