Looking for a 90 degree conn housing with leads that aren't exposed
Looking for a 16 pin connector with a right angle that I can solder on a board that is similar to PH2RA-16-UA but I need the leads to not be exposed to not short out electronics that will be touching. The mating distance is .1"/2.54 MM.
Hello alex.ashford,
Welcome to the TechForum, we have no part like you describe to offer.
I assume you want the leads that are soldered to the board to be covered? For this you would just get the shortest contact post length for your PCB and then pot over the connections.
23-0705530050-ND This is the kind of part I was looking for FYI. Sorry things can be kind of hard to describe.
