Looking for a replacement switch
I am looking for a replacement switch for a starter unit that I have for a radio control vehicle.
I have attached some photos of the faulty switch that is currently in the unit.
The black switch surround dimensions are measuring on my digital callipers at 15.4 x 19.4mm.
I would prefer a push button over a rocker style switch. Do you have an exact match or anything close enough that would be suitable to serve as a replacement?
Many thanks.
Welcome to the forum.
That looks like one of the major manufacturers but the logo and/or manufacturers marking is usually on the side without a photo.
If possible please provide a photo of the other side of the switch.
Trying to source a replacement/substitute going just by the electrical specs and one mechanical measurement is time consuming and may not get a suitable result.
Welcome to the TechForum!
I have found a similar option on the link below. More information would lead to more options, and I opened up the filters to find stocking options.
CKN4034-ND
8168J81ZGE22 C&K | Pushbutton Switches | DigiKey
Thank you
Ryan
Hi mjhowe29,
Unless it’s not important to you, the most important specs for a replacement panel-mount switch are the dimensions of the panel cut-out and the electrical specs. You have provided the latter, but that dimension would be most useful in narrowing down the options.
