Looking for volume knob for PTN09S2-H10120K1A
Hi, I couldn’t find it on here but I’m looking a volume knob for the above potientiometer (https://www.digikey.ca/en/products/detail/same-sky-formerly-cui-devices/PTN09S2-H10120K1A/24767413) that I’m going to purchase. I did find this one but can’t comfirm if it’s compatible:
https://www.digikey.ca/en/products/detail/same-sky-formerly-cui-devices/SAK-007/27527307
Are there any other suggestions if it’s not this one? Or what should I look for when trying to confirm compatibility?
Thanks
Greetings,
That knob is meant for a D-cut/flatted shaft, whereas the pot mentioned has an 18-tooth knurl/spline.
'Aint gonna fit without a dremel and some superglue…
First thing to look for in a knob is a shaft size that matches what it’s being put on. Allowing for a fractional millimeter give or take in one’s selection thereof is suggested, to account for variances that may exist due to an intended clearance or press fit.
After that one can apply and/or sort by other attributes of interest, then start checking datasheets for geometric compatibility. Something like the CL170846CR or FC7223 would probably work out a lot better.
Oh, that’s great. Thank you so much for that!
