DC2792B I will impose some restrictions on the management system on my motherboard the temperature should not exceed 60 degrees,if it passes, I will give the command to turn off the system,I need to transmit this error signal to my ams error latch circuit, from which pin of DC2792B can I receive this error signal and transmit it to my ams error latch circuit?
Hello melihgamze_1999 .
Thank you for contacting Digi-Key TechForum. This sounds plausible, are you able to provide more information or a schematic?
