LXML-PWC1-0100 - Lumileds
LXML-PWC1-0100 - stock available on the website .
Is it possibile to obtain the BIN list which forms the mentioned stock ?
Hello orsolya.berecki, welcome to the TechForum! Unfortunately, we do not keep track of all bins for any product. Bin codes generally fall within several groupings for LEDs which would add way too many SKU numbers. Generally, it’s better to check the datasheets if the tolerances are acceptable for the application and then find other series through research if you require tighter tolerances.
Hi Kaleb .
The point is if we decide to purchase from the website 100 pcs from the mentioned LED , is it possible to know which type of BIN they will send to us ?
Unfortunately, there isn’t a way to know which bins you will receive.
