M5stack A140 Connector compatibility with U153 8-Encoder Unit
Hello, hope all is well. I would like to know if the A140 CONNECTOR GROVE TO USB-C by M5stack is compatible with the U153 8-ENCODER UNIT, also by M5stack. Thanks
@shamardb
These should work together.
2221-U153-ND
2221-A140-ND
From the information the supplier has the U153 would also come with a cable, the U153 should be able to connect to the A140 via the cable.
Unit 8Encoder
Grove to USBC
thanks very much!
